メインコンテンツにスキップ
Samsung Galaxy Note 4は2014年10月にリリースされたスマートフォンです。Galaxy Note 4のモデル番号は、米国の種類のSM-N910、SM-N910A、SM-N910T、SM-N910V、SM-N910R4です。
256回答 すべてを表示
締切られた回答
My S pen of my Note 4 not work after phone drooped
A week ago I accidentally dropped my phone .
my cam lens bricked and i fix it as i see in your web site and thanks by the way
But now the problem is My S-pen didn't work on all screen but still works on sub key of back button and menu button .
and the phone still recognize when i attach it or take it out .
I tried to change the s-pen and put new ROM but the problem still as i describe
any suggestion i will appreciate it ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
I have this problem too. Did u get it fixed and how...thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have this same problem with my note 4. I dropped it face down on the screen, surprisingly the screen did not break. It has power, the top left power light and two bottom icon lights are on it still vibrates indicating messages it rings for incoming calls I can answer them because I know where to swipe to answer call, but I cant see a thing completely black screen. I have the finger swipe security that I can still unlock but nothing visible. Ive tried the soft reset holding down power button for 2 seconds to drain power and removing battery for 10 minutes but it has not worked for me. Please Help.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My s pen did not work in any way please help me if u can
さんによる
コメントを追加
Same problem, on back key and meni key s pen work, but on screen dont work. Anyone have fix?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
さんによる
Have u solved the problem?
さんによる
コメントを追加
I have the same problem!!!!! PLEASE HELP US
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well Im having the same problem as Stev, my s pen works on the bottom touchscreen buttons but not on the screen, im able to use the screen with my fingers tho.
I've been reading and I've found that the problem could be the S pen sensor screen which is behind the main screen, theres some video on youtube about how to replace it but seems to be like there's no guide here about how to do it in detailed steps.
Hope this helps, if anybody else knows anything else or somebody tried/solved it already, Please ill be grat to know.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have you got the solution to this problem ??
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 4,073
