I think I have lost my fusion drive
I have recently upgraded to El capitan, it crashed during upgrade and I had to erase the hard drive and start again from time machine back up
My drive now looks like this?
and is running very slow.
Where exactly did you delete the contents? (Disk Utility in the installer?)
We really need to see output from diskutil list and diskutil cs list in Terminal, but it looks like you might have partitioned the drives again while erasing. In this case the system will be slower because the OS is running from the platter HD, not the SSD.
What you need to do is start Recovery Mode, go into Terminal under the Utilities menu and run a few commands to recreate the Fusion drive. (Many DIY instructions on the net)
After that is complete you can restore using Time Machine.
このアンサーは役に立ちましたか?
In disk utility when crashed recovered into online mode, will have to search for commands then no good with terminal..
By online mode do you mean Internet Recovery Mode?
Here a re a few links:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,136
