Hi,
For you to connect if your friend is there he needs to turn OFF bluetooth in his device. Then you should be able to connect.
I think that since your friend connected first, there must be a priority connection order in the Braven therefore his connection gets preference.
I suggest you press the reset button. Hopefully this should restore the Braven to default and remove all bluetooth connections info. Then connect (re pair) your device first. Then if you want your friend to have access as well connect his device next.
The user manual is pretty light on detail. If you have further questions contact the maker at the following
http://www.braven.com/contact-us
Here is a link to the user manual.
http://www.braven.com/braven-brv-1-water...
My new phone (Galaxy A70) won’t even read the device. I don’t even have an option to connect to Braven speaker at all. Meanwhile my previous device (LG G5) can read and connect without any hiccups. I reseted the bluetooth but still it does not show anywhere on my new device. Any help would be appreciated. I don’t want to have to buy another speaker.
Igi Vasiljevic さんによる
@Igi Vasiljevic ,
Can your A70 "see" any BT device at all, not certain from your question whether it can see other BT devices or not?
try turning off the BT in all your other devices and then reset the speaker to pair again and then check if you can see it in the A70 BT menu
jayeff さんによる
