Clock is 1 hour out
how do i set correct time
この質問は役に立ちましたか?
Hi,
Check Menu -- Settings--- System --- Location
The LOCATION settings allow you to change the language display information of your console. If you move to a different time zone or region, you should update your console settings here:
Language & location
Language controls your console’s display language.
Location controls your console region, including for Xbox stores content.
Time zone
Automatically adjust for Daylight Saving
You can choose to have the console clock change automatically with British Summer Time.
このアンサーは役に立ちましたか?
Tried all but clock is greyed out so cant change time. Thanks anyway jayeff.
Hi,
you need to go into your network settings, and set your console to "Offline Mode". After that, then reset your console (this is done by holding the power button for about 10 seconds, or unplugging). When you power it back on, you should be able to change the time.
Just change the time zone to a different one, and then back to the one you are in! Literally did this 10 seconds ago and it worked for me :)
Hope this helps!
I Ave been having save issues on Xbox one version of mgs v
After completing a lot of missions,gone to mother base, being in aerial commands center. If then my console is off, I would have to start all over again cos it won't continue but return me to the beginning
At this point, a universal fix would be to just keep your phone or watch handy
このアンサーは役に立ちましたか?
Also anyone in the uk having this problem chose region casablanca, they are exactly 1 hour ahead, so our xbox displays correctly.
過去 24時間: 3
過去 7 日: 10
過去 30 日: 30
今までの合計 8,290
4 件のコメント
Wait till November 1, Daylight Saving Time Ends
mayer さんによる
not acceptable. that is not a fix.
Paul trotter さんによる
I held down the power button for 10 seconds and hours later I try to change the time but it's greyed out and I'm not connected to xbox live, I also restarted my Xbox one but it's still greyed out. How do I fix this?
TomboyxGirl さんによる
Mine is frozen at the wrong time and no matter what i do i cannot change it, so &&^&^$^ frustrating!!!!1
89thphoto さんによる
