Why does the vacuum not suck dirt even when powered on?
The vacuum is turned on, and I can hear it trying to suck the dirt up, but the vacuum is having a hard time pulling the dirt into itself.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Empty and clean the dust bowl, check the filter and make sure there are no obstructions.
このアンサーは役に立ちましたか?
Its possible u have something blocking the air way. That's why ur motor sounds like its working harder than it should. The item , sock, or wad of dirt MUST be removed or u will burn up ur motor. . . kk
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 366
