メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
締切られた回答
Issue with iPhone 5s
I have a iPhone 5s and I was using it and I noticed it was slow and lagging and then all of a sudden it shut down, went completely black, even with the battery at 35% and when I tried to turn it back on, it was unresponsive. So I decided to plug it in and it just stayed on the red power bar icon and when I would unplug the device, it would shut down automatically and would be unresponsive until it was plugged in again. I tried to hard restart it and it didn't work, it would only cause the device to go from the power bar icon, to the apple logo and then right back to the power bar icon. When I tried to restore the device to factory settings via itunes, it would go up until extracting the software was finished and then the device screen would go blank and then right back to the power bar icon, and with repeated attempts, I only garnered the same thing. Also, when it was plugged in and on iTunes, some times the serial number would come up and other times it would be appear as "n/a"
Is there anything I can do to fix this issue, and do any of you guys know what the problem could possibly be?
iPhone 5s, iOS 9.0.2
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I'm wondering if this is error 53...
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I'll bet ya a fair amount of money that it is a simple dead battery. Fairly easy fix for DYI and on the cheap side of iPhone repairs if you go to a shop. That exact scenario is part of the manual I created for new techs:
"If an iPhone will only boot, or boot loop while plugged into a charger, replace the battery and test."
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 137
