メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1979年にHPによって初めて製造された。
HP 41C Switching On Problem
I have 41C. Since last few days it does not switch on. It means it does switch on some time. The batteries have total voltage of 6 VDC.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
Hi, :)
- First test your batteries on load(connected to a load) .
- Check the batteries connection (flat-flex inside the batterie older (often corroded)
- remove the rubbers pads and unscrew the four vises (on the bottom), and check the flat-flex connetion on the main bord (alsow oftem corroded on this place).
If the flat-flex is not to much corroded, you can try to clean it, and the contacts (never use solvent on the ff).
- Take attention that the four vises apply a "pressure" on the flat flex (a kind of spoons on rear of the ff, maintain "flexible pressure"), check that all :)
Ok , let me feedback with your instigations
(i could send you link of tuto to fix this kind of flat-flex problems).
Regards , PVR
さんによる 共有
Tengo una HP 41CV que hace unos meses dejo de funcionar adecuadamente. Creí que eran las beterías pero las cambie y seguía sin funcionar. Se enciende y siempre indica memory lost y no sale de ahí independientemente de la tecla que pulse.
Yo supongo que tendría que reinstalar el software pero ni lo tengo ni se como hacerlo.
Si alguien me da alguna idea para repararlo se lo agradecería.
José María
さんによる 共有
コメントを追加
3件の回答
最も参考になった回答
Have a look on the flat-flex connector on the main bord. These connector is only pressed (with the four vises under the rubber pad). Often corrosion appear on this flatflex and disturb the HP41.
So let me know waths up ,
have a look on this :
http://www.clonix41.org/Maintenance/IO_B...
or this repairing video:
https://www.youtube.com/watch?v=jUTAZSEn...
Regards , PVR :)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Have a look on the flat-flex connector to the LCD diplay :
The kind of "connector" is only pressed to the main board. The four vises (under the ruber pads) mantain this on pressure . Take care of clean contacts ereas (never use solvent to clean it).
Let me know wath up :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, :)
Regards , PVR
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dattatraya さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 39
今までの合計 3,813
