メインコンテンツにスキップ
The Ninja Professional Blender 1100 watt model BL663CO, is a high-performance blender used for ice crushing, blending and pureeing.
14回答 すべてを表示
Why is the lid so hard to remove?
After using my Ninja blender, the lid is always stuck. I always have to ask my Dad to remove it. Why is it getting stuck after I make my smoothies?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
11 件のコメント
Having the same problem… Will never buy another Ninja product… Too frustrating…
さんによる
Mmmmmmm...... it is a good product; just don't store with lid on tight...
さんによる
Look where the handle attaches to the lid, you will see white latches, one on either side, lift them up with either a small flat head screw driver or, the blade of a pair of tweezers. The lid will come off just like magic.
さんによる
I used Pam spray and pried it off with a flat head screwdriver. I won’t store with lid on and lightly spray lid before usage.
さんによる
Same problem years later - so frustrating. Will never buy another Ninja product.
さんによる
6件以上のコメントを表示
コメントを追加
10件の回答
ベストアンサー
If you use the dishwasher to wash your blender components, make sure to allow several hours for the all the water to dry, especially for the lid. If there is still excess water between the seal of the lid, it can create a tight suction and make taking off the lid difficult after blending.
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
still stuck it sucks
さんによる
Still extremely difficult to remove. I've stopped using the blender because of this. It's a real design flaw.
さんによる
I have the same problem!
さんによる
Same here. If it isn't tight enough liquid leaks during the blending, but if it is tight enough for that not to happen it is extraordinarily difficult to remove. I've mostly stopped using, too.
さんによる
After trying everything to get the cover off, and no I did not wash it in a dishwasher, I used some WD-40, and it came right off. Use a good degreaser to wash the WD off. Blue Dawn dish soap works great.
さんによる
4件以上のコメントを表示
コメントを追加
I used hot water, no help, tried to pry off, would not budge. I was spraying a squeaky hinge with WD 40 and decided if it would unstick other things, it might unstick the lid, one squirt on all 4 sides, and the lid came right off. Now I know to not store with the lid on.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you haven’t used it for awhile and it is stuck on, you have to muscle it. A man with big hands ( sorry feminists) and fingers should be able to do it easily. I am a medium build man y with skinny fingers. Undo the latch, place the tips of your fingers under the edge of the lip and pull like crazy. It hurt so bad that I used a dish wash cloth. I put my left arm around the pitcher, gripped it, gritted my teeth, told the lid that it would lose and I pulled it right off. Suggestion: don’ t store with the lid all the way down.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I used Olive Oil around the lid edges. It took many tugs to pull it off as I am not very strong but dont give up. It took me about 5 minutes of tugging for it to finally come out of the blender.
さんによる
Put lots of rubber on the lid,twist and will open easily.
さんによる
コメントを追加
Mine leaks and so I wanted to replace the seal.
I was unable to find a genuine seal on the Ninja website, so I called them…..
I was informed that you need to buy the whole new blade set as they don’t sell the seals.
I won’t purchase another Ninja for this reason.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
don't put lid put in side
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I do that still stuck it sucks
さんによる
コメントを追加
The rubber is may be missing or off the lid.
Twice I tiressly struggled to take off the blade lid I realized the clear plastic circle that goes in between the blade lid was off.. I usually take it after using the ninja when cleaning
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just used a table knife to carefully pry it off.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Actually, the big thing that you need to loosen the cup from the blade is a good grip. I finally realized that by putting on simple dishwashing gloves I was able to grip both the base and the cup and give it enough of a pull to where I could separate the two. I find that it only gets stuck if I overfill. Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Super simple fix to remove the lid. Fill pitcher with hot tap water. Let sit for 60 seconds. Then slowly pull off the lid. I’m a petite woman with small hands and I was able to pull off the lid after this quick fix. From now on, don’t store with the lid on.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Boiled hot water, set it in pot for 5-10 seconds, used rubber mit twisted hard still a little tight but did come off!
さんによる
コメントを追加
Problem solved. Most people are not lining up the arrows (small white arrows) on top to each other. There is a small pin that locks the lid tight when properly aligned. When you push down on the release button, and pull up on the handle; it easily releases. I would also leave the lid loose on top when not using it, as other people have suggested.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Put lots of rubber on the lid,twist and it will open easily.
さんによる
I am lined up but cannot get it to pull off after pressing release button. Could the blade inside be holding lid in place? Never used it yet.
さんによる
I finally got it pulled off!
さんによる
コメントを追加
回答を追加する
Dave Bohling さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 113
過去 30 日: 581
今までの合計 105,049
