メインコンテンツにスキップ
Huawei P8 Lite(モデル番号ALE−L21)は2015年4月にシンプルな美しさをテーマに発表されました。プロ級のカメラは、暗所でも自然やシャープな画像を撮影できます。
Phone Microphone only works in calls but nothing else
Recently, my phone's microphone stopped working which means it doesn't record sound in videos or audio recordings and also doesn't work in apps. The only exception is phone calls where it does work. Why is this? This has happened a long time ago before and it fixed itself so I left this issue for a while but it's been about a month or so and still nothing has fixed! I need my microphone to work asap because I need to record videos WITH audio for my school project! Need help!
Note: I have tried rebooting my phone
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
My p8 lite does not ring or play sound /alarm / music and it is one week old
さんによる
コメントを追加
3件の回答
最も参考になった回答
superelectrolizard ,
it is not software fault. your P8 having secondary mic (use for nice cancellation and voice and record sound with comparing. simply you can find it near the Headphone connector.
Here you can find teardown guide. check the mic contacts connected properly to logic board or replace the mic and see
as you mentioned on your question : not required to test primary mic as it works fine (bottom side mic)
Hope this answer will help you to understand the fault and fix it your self
Cheers!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Buddy it seems like a software issue. Try factory reset but don't forget to take backup of your files. Mostly that should make it work!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi I have Huwaie p8 lite problem in my mobile is mic ni nothing working.during calling I used head phone.pls tell me how to resolve
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
superelectrolizard さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 17
今までの合計 7,085
