メインコンテンツにスキップ
250GB HDDとWi-Fiを内蔵したXbox 360のスリム版も出る。修理には複雑なこじ開け作業と特殊な工具が必要です。
307回答 すべてを表示
Xbox will not power up, power supply light is orange, no POST
Hello, I have an Xbox 360 S that is having issues. One night while watching Netflix, the whole thing just shuts down. No power. So, I try all I can, the first thing I thought is that the Xbox overheated, and it was only mildly warmer than usual, and there was no overheating error code on the screen. It was just fine to a black screen. The power supply's light is orange, which means the power supply is reportedly good, but I'm not so sure. Xbox Support said that it's a hardware issue, and of course they would be glad to take it in for the steep price of $99.99. I of course knew this was a ripoff, considering it is out of warranty, etc. So, this is what the console does now. The light on the power supply is orange. I go to turn on the console, and there is no POST. It receives power, the light turns green on the PSU, and then it shuts off again, not displaying the Xbox splash screen or anything. I have no aversion to cracking the Xbox open, considering it is out of warranty and probably needs a nice clean and repaste anyway.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
My friend had the same problem. take the xbox into a GameStop or what ever retailer like them near you and ask them to see if plug in a new power cable into the console will boot it up. It worked for them and they didn't need to open it up or send it in
Hope this helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have old Panasonic 42" Viera plasma th42pv8h tv. One day to other i can't turn on. Switch on TV, led blinking green fast and started blinkin 10 times red. First switch on get a popping sound whitout smoke. I want to fix if it can be. Help somebody or ask a tip, Thank you! i connect the all cable and all prot but not worcking
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
cad5359 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 4,966
