メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
Touchscreen not responding after replacement
I replaced the screen on and digitizer on my wifes 6 plus. Screen picture is fine, turns on fine, home button, power button, volume, vibrate all fine. Touchscreen not registering any touch. I have disconnected the LCD cables and reconnected them to no avail. Any help in fixing this issue?
Replacement part is from TechOrbits, purchased through Amazon. Any help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
Hi Ernest,
As the others have said this could be a quality issue, however I have had similar issues with the iPhone 6+ which was easily rectified.
The iPhone 6+ has two rather long connectors from the LCD and Digitizer Assembly, one for each respectively. Due to their length, these connectors sometimes have issues making full contact with the headers. As they are slightly malleable, you will find they often flex in a concave fashion, or perhaps one end will be lifted. Removing and straightening the connectors so that they make full contact with the header is a quick fix, and can sometimes get you out of trouble if a new screen isn't displaying or the digitizer isn't functioning correctly.
Again, this may not be the issue, but as the iPhone 6+ has longer connectors for the screen assembly, it is worth checking out.
Calvin
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Amazon/eBay screens are almost always pretty low quality.
In China, the best screens go to the big fish parts sellers that are standing there at auction. The leftovers make their way to Amazon/eBay.
Your first move here is to rule out bad screen.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Disconnected and reconnected the LCD cable and it started to work properly however the left side of the screen isn't working still. I'm going to attempt to unplug and reconnect loose cables and it helps
さんによる
コメントを追加
I'm sure this has to do with the screen quality. You could disconnect the new screen and reconnect the old screen and see if the touchscreen works on that old screen, if it works it's going to be a screen issue. Also try doing a soft reset holding down home button then power button until the apple icon comes on.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
As Calvin said,
The connectors are comparatively longer than 6 or 5 series,
Many of the times the 3rd party replacements don't align good and you don't hear the click sound on snap in.
Straighten the connectors again and try to feel the positioning with your finger don't push it hard you will know by the feel when it's ready to go in and snap it in if you don't hear an audible click check again but if you hear a low click you are good. Press the connector with some force now and you should be good.
Sal
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ernest さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 11
今までの合計 300
