メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.6 GHzまたは1.8 GHzデュアルコアプロセッサ、2 GBまたは4 GBのSDRAM、64 GBまたは128 GB SSD
Keyboard row doesn't work
Whats up guys, I JUST finished changing my battery on my macbook, and now my a s d f g h j k l keys don't work, all other keys work fine. I was wondering if I might have loosened the keyboard cable or something. I'm going to take it apart again and see if anything is loose. Which cable is the one for the keyboard? Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
I'm sorry that you're having trouble with your keyboard. Unfortunately, Apple (we all know the designers at Apple can do this if they are feeling dubious) has decided to embed the keyboard in the upper case in your model, and the keyboard cable and assembly is in the upper case. Depending on how many repairs you have done before, this could take anywhere an hour for experienced professionals to three hours for beginners. If you want to proceed, you can use this guide (MacBook Air 11インチ Mid 2011 アッパーケースの交換) to try again. You also may want to reseat the battery connector before trying. Hope this helps.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Good news, I removed the battery and wiggled the ribbon connectors and reassembled everything and it worked. The keys are working now haha I guess I got lucky. Thanks for your help anyways
さんによる 共有
コメントを追加
回答を追加する
Mark Chang さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 5
過去 30 日: 21
今までの合計 454
