What should I do if my screen is not working?
The device's screen is malfunctioning, and is unresponsive. The image on the screen will not change when I touch the screen of the tablet.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try resetting or rebooting the tablet. You can do this three ways:
Try turning on the device. If the device still won't turn on, then the memory storage may be full. You can expand the memory storage up to 32GB by adding a SD card.
If the above does not work, then the problem may be with the screen itself. The screen may need to be replaced.
Check out our Troubleshooting page for more information.
このアンサーは役に立ちましたか?
turn the %#*@ screen on and shoot at your device;)!)
このアンサーは役に立ちましたか?
poo into the reset slot
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 7,900
