メインコンテンツにスキップ
HPによるフォトインクジェットプリンターモデルの修理ガイドならびにサポート情報。
289回答 すべてを表示
Screen says there is a jam, non seen, where to start?
I have a HP Photosmart 2610. The screen indicates a carriage jam, to open, clear the jam, close the door and press the OK, and resume.
The resume however is just back to the same jam screen.
Where to start?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
ベストアンサー
If you have completely cleared the jam, I would reset the printer. The manual should explain how to do this. Or you can try shutting it off and removing it from power supple for a minute or so then re-connect.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
さんによる
コメントを追加
If you've done all the HP-recommended steps and the ink carriage seems to slide easily with the printer off, there's one more step you can try, if you don't mind getting ink on your fingers.
With the printer door open and the cartridges out of the way, see if your printer has an inkjet wiper tray that sits under the cartridges on the right side of the printer. The tray should slide easily backward and forward, at right angles to the print carriage, with just a little hesitation when the wipers go under a scraper bar that sits behind the carriage.
If the tray feels sticky, ink may have accumulated in the tray's guide rails. (My c4385 had printed almost 9000 pages when this happened.) You can clean the rails with cotton swabs and rubbing alcohol (I used cotton balls, a hemostat, and cheap vodka). I didn't go nuts, just cleared where the moving parts slide. I was careful not to get alcohol anywhere where ink doesn't normally splash.
When you've got the tray moving smoothly, make sure you remove any stray cotton fluff, especially from the rubber wipers. Then close up the printer and print a test page (On the c4385 press the Cancel and Green buttons). This cleared up the issue for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My hp 2545 deskjet printer continue display paper jam no paper inside the printer
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MTL さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,314
