メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
締切られた回答
trying to reinstall os x lion but my hardrive is locked
i am forced to reinstall os x lion as my harddrive or mac has an issue.
my mac is not booting correctly so i do it in the save-mode (i speak german so i dont know the right term for it in english (however pressing alt+cmd+r+ turn on button). i can see that my HD is locked and i cant select it when i want to reinstall mac os xlion. in 'disk utility' i varified and repaired the disk and the message in SMART says verified, unfortunately i cant hit 'enable journaling' as its unclickable. please help me i need my files and i know they are there, ps. sorry i dont speak the mac-tech language, even if i used all this terms above, so please write as easy as possible :D
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
short update about the verifying, i didnt do it on the macintosh hardware, but on the hardware that has been installed once it was broken, trying to do the varification and repair now, hope that makes sense
さんによる
didnt work, unfortunately i cant do a back up as my mac wont start properly!
さんによる
コメントを追加
2件の回答
ベストアンサー
Enter your administrative user password to unlock the disk. Do not upgrade to El Capitan yet as the Disk Utility on that version will not do the job.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
thx, but where can i type in the password?
さんによる
Type it in when you use Disk Utility.
さんによる
can you give the step by step process of getting the hard disk unlocked?
さんによる
コメントを追加
Maybe you can try diskwarrior, just search over the web (torr3nt) and youll find the boot dvd, maybe it works for you...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
hi makomail, thx ill try to search it on my ipad and let u know
さんによる
ok, just let me know about your progress...
さんによる
hi there, i went to the appel store, what they did was saving my documents (some or the most important ones got lost) to en external harddrive by creating two partitions, one for the backup and one for the system, through the new system i could drag and drop by data onto the external hd. then they set it up all new from scratch, i have my data now, but all aps and softwares are lost...well $@$* happens and inreally learned my lesson about backups!
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 9,184
