メインコンテンツにスキップ
Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
no signal from computer to moniter
Their is no signal from my Asus essentio to the monitor . The monitor is working fine as I have cctv cameras attach to monitor and it is displaying them fine, I have also checked cables which are all fine. This has lead me to believe that this could be the graphics card . I have taken a look inside the computer and I can t see the normal set up with a removable graphics card attached to the vga port so I am now wondering if the whole motherboard needs replacing. Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
haguehags ,
Hope This answer will hep you to get idea to fix you PC
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
this isnt hel[ full
さんによる
コメントを追加
Greetings,
Check the monitor for which type of input signal it is currently set for.
- there should be a choice within the set-up options for Dvi, HDMI, Display port or whichever cable type the Pc is connected to the monitor with.
- insure that the cctv cameras are not set as the default source.
Hope this helps in attaining a signal.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
asus pentium3 power ok ram clean ok showing signal ditected
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
haguehags さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 4,503
