screen broke from the inside can I fix it
My tablet got crack from the inside can it be fixed. Some one please help
patty abarca, from what you are describing it sounds like a broken LCD but intact digitizer. It will help if you post some images of what you see with your question. Use this guide to do so. The LCD's are readily available at places like this and many others. There are no repair guides out, so I would suggest that you check check on here as well as on here for similarities. When you do decide to work on it, [URL|make] create a guide so we can all learn from it.
ガイド
難易度:
とても簡単
2 - 5 minutes
ガイド
難易度:
難しい
30 - 40 minutes
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 393
2 件のコメント
does the tablet still work?
Power on can you see the screen and does it respond to touch
Jimfixer さんによる
It turns on but all u can see is liqud. No it does not respond to touch
Lewis Jones さんによる
