メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2623回答 すべてを表示
Samsung HP-T5054 tv. Video issue
The tv outputs video at a very dim level, like you have to squint to see it. No sharpness to it and very fuzzy. Doesnt matter whether hdmi or component. Ive adjusted picture settings and reset it to factory settings, no luck. So i believe its a hardware issue. On top of that one of my hdmi ports doesn't work as it just outputs blackness.
Not sure if related or not.
I'd like to repair it, but wouldn't know where to start looking, I just build computers.
What do you guys think it is?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
joshbarber89 I recognize this is an old question. Having just gone through one of these I thought I could at least answer for the next person with this TV. Problems with the display appearing dim and washed out looking as well as a poor black level is usually caused by a bad main board (“one of my hdmi ports doesn't work” more evidence of that) . The issue with this particular model Samsung TV is that they had capacitor issue on the power board which Samsung even had to pay a settlement. So you’d be looking at the main board first, then power board after that you would have to check the voltages on your Z-sus board. Lastly, a bad panel can give the same symptoms.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
joshbarber89 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 72
