Why does my computer take a long time to turn on?
My computer is taking longer than usual compared to when I first purchased the computer.
Depending on how long you have owned your computer, it is common for a computer to slow down with the more information you are storing on your device. Music, pictures, and anything else that you have saved onto your Dell laptop takes up storage. The more item you have stored will cause the computer to slow down. Try deleting unused items off your computer and see how your computer responds to that.
Also take a look at our troubleshooting page for more information about the device becoming slow at Dell XPS 15L502X Troubleshooting
このアンサーは役に立ちましたか?
What happens over time is you install programs, then eventually uninstall them continuously. But uninstallations don't necessarily remove all traces of the program. It may still leave traces in the registry.
The registry is a giant library that holds key details of all programs you installed as well as info for the operating system itself to use. This giant library has to load before you see the window gui (the homescreen ).
Disk defragging will help organize the registry so calls to your hdd or ssd (harddrive) are quicker. also a free program called CCleaner can help with some of the unnecessary registry items in your registry.
In short use CCleaner to clean your computer of unessary files and disk Defrag.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 417
