メインコンテンツにスキップ
Product was released in 2009 by Presto. It can be found with Model number 04820.
2回答 すべてを表示
Why did my hot air popper stop working mid-use?
The hot air popper was working fine and then it suddenly shut off. Why did it do this and what should I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
The engineers at presto had a delicate balancing act. Too hot and it could start a fire. chances are you were trying to make more than a half of cup of popcorn and live at an altitude greater than 2000’. In addition to the thermal fuse a thermal switch was installed to prevent overheating. All testing for Presto was completed in EuClaire Wisconsin (low Altitude). My 10 yr old daughter tested ours out at many different altitudes and found that the fan they installed only works as designed in denser air (low altitude). If you live in Denver Colorado or Park City Utah a half cup is all you’ll ever get out of it before extensive cooling is required.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you! I was about to trash it, but this solves the mystery. Works fine with no popcorn. Was shutting off after a few seconds when overloaded and living at high altitude!
さんによる
コメントを追加
If the popper is plugged into the appropriate outlet, and the power cord has been thoroughly checked then the motor could be bad. To fix this issue change the motor.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
The poplite does have a thermostat on it as a safety function. If you pop too much too often, the unit will get too hot and will stop.
さんによる
What if it doesn’t heat up once plugged in ? Junk it ?
さんによる
Check your breaker box.
さんによる
コメントを追加
回答を追加する
Haley Stone さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 32
過去 30 日: 130
今までの合計 6,191
