メインコンテンツにスキップ
An 8 inch Capacitive Dual Core Zeki Tablet with dual cameras. The model number for this device is TBQG884B .
What can I do if my tablet keeps restarting?
My tablet keeps restarting until it is out of charge. How to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
コメントを追加
3件の回答
最も参考になった回答
There are a number of potential causes for a smartphone or tablet repeatedly and unpredictably restarting itself. Please follow the steps below to troubleshoot this problem with your device.
Download the latest software update
The current software update for your device may fix any bug(s) that are causing the restarts. Follow these steps to download the latest software update for your device. Note: the steps required for your specific device may vary slightly from the following.
Make sure your device first has a WiFi connection and then on your device go to Settings > About Device > Software Update and then touch Update.
Remove the external SD card
If your device contains an external SD card please make sure your device is powered off, remove the external SD card and then power on the device again and see if any further unexpected restarts occur while your external SD card is outside the device.
If your device works fine without the SD card it is very likely the SD card is at fault. Delete all software on the SD card and see if your device works with the SD card after you have wiped it of data. If your smartphone or tablet still restarts unexpectedly while the empty SD card is inside it the SD card likely has a hardware fault and will need to be fixed by an engineer or replaced with a new SD card.
Perform a factory reset
A factory reset will restore your device to the state it was in when it left the factory. This means that all the changes you've made to your device and all the media you have stored in its internal memory will be wiped, so please make a backup of anything you don't wish to lose on another device, such as a PC. When you've safely made back ups of all your important data follow these steps. Note: the steps required for your specific device may vary slightly from the following.
Go to Settings > Back up and reset > Factory data reset and then touch Reset device.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
It rounds like you have a corrupted firmware. Go to the manufactured website and download the latest firmware for your device and restore.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Have you tried turning the device off and turning it back on?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Yep, but I cannot turn if off, because it restarts again.
さんによる
You might have a faulty power button. Have you checked to see if your power button has a short with a multimeter?
さんによる
Not yet. I will try it when I get a multimeter. Thank you David
さんによる
コメントを追加
回答を追加する
Linlin Cai さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 1,966
