How do I fix a stuck lens?
My camera lens is stuck. Is there any way I can fix this on my own?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Stuck lenses are a common problem. Usually, it's caused by sand or dirt inside the mechanism, or the lens has been dropped. Sometimes, you can't repair it yourself and you will need to take it into a repair shop. However, you can first follow the steps in this guide to see if you can fix it yourself.
このアンサーは役に立ちましたか?
If you r lesn has fallen and as a result is stuck, I have found on YT a totrial that can help. It has worked for me and saved me quite an expensive repair. I ahve copied teh title and link to the video below, good luck:
HOW TO Repair A DSLR Camera Lens That Is Crooked And Jammed After Being Dropped #DIY #Repair
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 26
過去 30 日: 125
今までの合計 42,326
1件のコメント
I cleaned it with paper worked great
Andrew Howell さんによる
