メインコンテンツにスキップ
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストーレッジは128GB もしくは256GB
147回答 すべてを表示
締切られた回答
Connector on I/O Board
So i had a issue where couldnt charge, no sound etc
Took my Mac apart and the cable had popped off
2 weeks later and it appears the same thing has happened. I suspect the cable is not fitting as snugly as previously.
Can anyone suggest a glue of adhesive i could use to secure the cable in place.
If it breaks again its probably getting replaced so im not too worried about the cable being difficult to replace
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Use any glue that's made for plastic and isn't conductive and you shouldn't have any problems for a short term fix. Ask in your local hardware store.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 74
