My acer tab's display is frozen, what should I do?
The image on the display remains the same. Unresponsive to touch. Unresponsive buttons.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If your screen is frozen you may need perform a hard reset on your device in order for it to be functional again. If your system is still frozen, you may try using the hardware reset pinhole on your tablet, to see if it will allow your system to boot.
Please follow the hard reset instructions.
1) Press and hold the power button and volume + button until it vibrates
2) Release the power button and unlock the screen lock switch at the side of the device.
3) The device has been restored to factory settings.
For more information please visit our trouble shooting page:
このアンサーは役に立ちましたか?
Worked right away
My screen acer iconia is frozen when I was downloading a home app called emoji phone, this process wasn't completed so after that the tablet is black, frozen; if I opened yahoo, after three minutes becomes frozen, when I opened Facebook after some minutes frozen and the screen appears black. I tried to reset but nothing, I tried to open settings but nothing appeared. What should do I?
このアンサーは役に立ちましたか?
My screen keeps pausing. I push the power button so it turns off(not completely off) then push again so screen comes back on. It then works for a few seconds then starts all over again. Why is this?
このアンサーは役に立ちましたか?
Mine does the same thing. I can't even update it.
過去 24時間: 4
過去 7 日: 7
過去 30 日: 34
今までの合計 26,234
