surface kickstand scew missing
Do you have a surface rt kickstand screw?
Normally, if you contact the manufacturer, they will supply you with a replacement for free.
I would imagine they should still have replacement screws.
このアンサーは役に立ちましたか?
You could contact the manufacturer and they should be able to send new screws to you. If that does not work, replacement screws are available at local hardware stores.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 9
過去 30 日: 10
今までの合計 276
