メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
締切られた回答
iPhone 4s battery life is only 5 hours with new battery
My battery seemed to die after 4 hours, so I replaed the battery.
Now after a full charge I still seem to get only 5 hours.
The only thing running is phone service, Facebook notications and messenger.
I did notice the phone getting warm, but not hot to abnormal.
Any suggestions on what the problem may be?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Where do you get the battery from? Maybe the battery has been used or it is a fake one. Suggest you choose a reliable supplier like hcqs.cc to get a original iPhone 4s battery.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
the first battery was an ebay battery. i thought that it could be just as bad as the old one.
the new battery is from ifixit.
no change.
さんによる
Yes , the reliable supplier is very inportance
さんによる
コメントを追加
It is worth buying a battery from a reputable supplier, eBay batterys can be all over the place.
But you would expect even the poor quality battery lasted longer to start with.
I would do a hard reset (DFU ) https://discussions.apple.com/thread/526...
Make sure you back up first
After restarting turn off everything that uses battery power. wi-Fi, Bluetooth. See how long the battery lasts for.
If you still having problems, probably you need to a get a repair shop to test the draw from logic board.
James :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The only thing that makes it last longer now is to turn the 3G off.
Now it lasts 6 plus hours.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 149
