Why does my scale have a bunch of random numbers on it?
Sometimes when I'm using my scale it shows 88888 on the screen. That is not the correct weight, what do these numbers mean?
Hey John, what you are seeing is most likely an error code that is built into the device. The code "88888" points to an overloading error. Please ensure that the weight you placed on the device is under the 100 gram maximum capacity of the device, as it could damage the device. This error should disappear if the weight is within the appropriate range. Let me know if you have any other issues.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 274
