メインコンテンツにスキップ
Samsung Galaxy Noteシリーズの第三世代ファブレットです。2013年9月25日に発売されました。モデル番号はN9005です。
248回答 すべてを表示
Replacing Display on Samsung Galaxy Note 3
Can I replace the Front Glass from the LCD display using the iOpener? Some blogs suggest replacing the full display. Posted videos show the Front glass removal using a heat gun or some other forms of heat. The iFixit guide for the Samsung Galaxy Note II provides instruction for replacing the front panel display assembly as a whole.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Like every Samsung glass it can be replaced with some skill and patience.
Honestly, I wouldn't recommend attempting it. It's going to cost you a fortune to fix if you fail and break the AMOLED display.
Definitely don't use an iOpener. If you're going to attempt it you need a heat gun and playing cards at least.
Here's a few tips if you do decide to attempt it:
- If the card isn't cutting through the glue easily then the glue isn't hot enough.
- Don't exceed 90 degrees C. Keep the heat constantly moving and not fixed on one position or you will burn the polarizer.
- Don't cut in from the sides/top with anything sharp or risk cutting the polarizer.
Removing the glass is the easy part, the hard part is putting the new glass on and making sure glue doesn't leak anywhere else.
I'd suggest removing everything from the frame so you can clean the excess glue.
Good luck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Serveitup さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 174
