Fans at full speed and slow to install/run
Hi everyone.
I've recently acquired a 15" 2010 MBP and about 10 seconds after the power button is pressed, the fan go at full speed. The OS loads and is sluggish so i installed Macs Fan Control and all temps were 40 degrees or below so that's not an issue.
I reset the SMC and PRAM to no avail, so thought perhaps the HD was failing so i tried a clean install on an SSD and same thing.
Has anyone had any experience of the SATA cable being the culprit here? I've had this on others when it was sluggish but i don't recall this affecting the fans. I'm wondering whether this cable may not be seeing the SMART details on the drive and causing this.
Any ideas would be gratefully received.
Thank you.
Paul
