メインコンテンツにスキップ
Released August 22, 2013. Identified by model number NP940X3G.
15回答 すべてを表示
How to upgrade SSD?
I've opened the back cover and removed the battery, but I see no mSATA. Where is it?
Update (09/25/2015)
Please see the pictures I've posted of the inside of the Ativ book 9+. Is there an mSATA SSD in this laptop?
Update (09/25/2015)
Attached pictures.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
i cant see any mSATA on this board. There is a place where it says 2nd SSD but as far i can see there is no connector. I think it is not possible to build a SSd with mSATA in this Laptop.
Sorry to say that.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hy William
When you open the Notebokk, is there a orange cable on the left side of the Batterie?
if yes, under this cable, you will finde the mSATA connector.
Greetings
Daniel
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Unfortunately, no orange cable. There is a piece of plastic, looks like a spacer. There are two wires connected to this piece of plastic, very thin wires look like power, red and white.
If it is possible to post a picture here, I can share a picture of the inside of the laptop.
さんによる
You can ad a picture by making a new answer and click the picture button
さんによる
コメントを追加
回答を追加する
William Beldham さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 5,229
