My phone got wet and shorted out
Can I retrieve my information from my phone it short out got wet
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You wont be able to retrieve any info unless you can get it to turn on , Try taking the phone apart and cleaning with isopropyl alcohol then get another battery and see if it will fire up if it does get whatever you can off the phone cause it may not work long
このアンサーは役に立ちましたか?
If you can take out most of the parts including the board soak them in isopropyl alcohol its not good to soak or get it on the lcd
過去 24時間: 1
過去 7 日: 5
過去 30 日: 8
今までの合計 414
