メインコンテンツにスキップ
10.1" tablet released in February 2014, powered by a custom version of Android 4.4 KitKat, and identified by model number: SM-T520NZKAXAR
20回答 すべてを表示
Why isn't my tablet making any sound?
My tablet isn't on mute or silent, and my volume button works and is turned on. However, it isn't making any sound or noise at all no matter what I do.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 20
2 件のコメント
Did it get dropped
さんによる
I did not drop it
さんによる
コメントを追加
3件の回答
ベストアンサー
If it's a software issue; you can do a soft reset by holding down the power button for 8 seconds until the device turns off. If that method doesn't work you can do a hard reset of your device but make sure to perform a backup so you wont lose all of your data. If that method doesn't work you can put your device into recovery mode by holding these buttons at the same time while your device is off; power button, volume up, and home button. Use the volume button to scroll and select the option wipe device/factory reset. Then select all user data and press the power button to confirm. If this method doesn't work you might have to replace the motherboard. You can find replacement guides for the device on this page.
Take a look at this page if you come across more problems on your device.
Samsung Galaxy Tab Pro 10.1 Troubleshooting
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thanks for your answer my device it perfect again I was so upset when it lost volume when I was in lock down due Corona Virus inside house
さんによる
Where is the power button.
さんによる
-_-‎‎‎‎‎‎‎‎‎‎‎‎
さんによる
コメントを追加
Why is my &&^&^$^ tablet working
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Kids e dong have sound either
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Stephen Yeung さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 23
今までの合計 22,929
