Why is my tablet frozen on the Acer screen?
So a few days ago, out of nowhere, my tablet shut off and is frozen on the Acer screen. I already tried the reset and factory reset but it refuses to get off that screen!!! Pliss halp!!!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hold down on the power button and the volume down buttons for a 10 sec then do it again for another few seconds. Hope this helps
このアンサーは役に立ちましたか?
I tried these combinations and this did not work. I got a green android character displayed on the screen with a rotating symbol on its front side. After this completed, the green android character ended up in its back with a exclamation point above him. I'm assuming this is not a good thing. I thought maybe replacing the board containing the ram may be the next thing. I did not see any guides for this here. Has anyone tried this? I'm assuming it's the main board. I appreciate any info.
I feel that jumping from a default reset straight into swapping out the motherboard may be a bit more drastic than most people would like. There seems like there should be other options available at least. I'm currently researching this anomaly for a different tablet, the Pro12, which is having similar issues.
Hi I have a similar problem my Acer goes past the Acer screen to where the android word pops and it changes from blue to white , back and forth. Then the Android word disappears and within about a minute it comes back, about 3 minutes later it disappears again and just continues to do this. I have tried to reset it with no luck. Does anyone have any suggestions?
このアンサーは役に立ちましたか?
@mjhickey61, were you ever able to get your tablet back to working functionally again?
i have the same problem and you didn’t have a reasonable answer what to do with it if the reset didn’t work ??????
このアンサーは役に立ちましたか?
So, apparently there is no one with any give a %#*@ that wants to help us. Sorry y'all.
過去 24時間: 0
過去 7 日: 7
過去 30 日: 26
今までの合計 5,369
1件のコメント
i didn't no my password again
Rukayatu さんによる
