メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
Mower deck not engaging
i have husqvarna model EZ5426BI mower deck will not engage. Just had the mower serviced than was mowing the lawn and IZT belt broke and was replaced and found the Deck belt had crack so I replaced it and now the deck will not engage
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Generally speaking, when it works until you fix it, you should go back and double check the work you did. Probably got the deck belt routed wrong - go back and make sure you are on the right side of every guide and pulley.
さんによる
コメントを追加
1 件の回答
You might want to check you ingagement lever and see if the cord that goes from the lever to your deck is broke
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bhagwanji Gosai さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 121
