メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
Galaxy S3 EMMC problem?
Hi everyone,
a friend has given me a Galaxy S3 saying it's not working.
1) I tried to boot it and I get a "white rain" effect. I have seen some people on the internet have this problem too, and it's because of the EMMC chip.
2) When I boot it in download mode I get the screen you can see in the image.
What is the better option?
Should I sell it (the phone is in excellent conditions) or replace the motherboard (the cost looks high on eBay)?
Do you know anyone who could repair the EMMC chip for cheap?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 13
4 件のコメント
I also have these problem,, Now I can't turn on my phone..
さんによる
my phn emmc problem not flash
さんによる
ı have the same problem with my galaxy s3. ı will buy a new one but ı have realy important pictures in my phone is there a possible way to get them
さんによる
can u pls tell me what happened with u cos i have the same exact problem right now
さんによる
コメントを追加
5件の回答
最も参考になった回答
Dear uchika96 ,
Before touch the hardware you need clear understand that the fault can't be fixed on software level.
Try to flash using Odin tool : fallow the instructions
if the firmware flashing gets failed try again to flash it
as you mentioned snow rain effect comes due to fault of EMMC, if you have sound BGA reworking skills you can replace the chip
Here you can buy item if required.
i did EMMC replacement on 2014 December and phone still works fine. so many professional volunteers here will help you to fix your phone. let us know the result
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
The screen is all you need, the logic board isn't worth much these days.
In the UK I can pick these up for £15-£20 in my area.
You can remove the eMMC and use an SD card as a replacement.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hi, I have the same problem, I looked for a mobo on eBay but not found these prices, do you have special suppliers for a mobo with a usable IMEI ? My S3 mobo is 2012.06.08. Thx for any help.
さんによる
Sorry, forgot a question: it's actually possible to remove the eMMC and use only the SDcard ??? It would be wonderful!
さんによる
if EMMC is removed how does the SD card work. Can you please show us steps or some other information which I can use for my mobile.
Thanks
Nir
さんによる
コメントを追加
I think replacing hardwares would be your last option. Try fixing that by flashing in odin or sp flash tool before touching the hardwares.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I will replace emmc https://www.facebook.com/permalink.php?s...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The root cause is a faulty firmware in the Samsung GT-I9300 eMMC chip (VTU00M) used in the first products,
The solution is to update the eMMC firmware, I just did got the same problem and the solution works 100%
Here is the explanation of the problem: https://www.youtube.com/watch?v=OY7OlY0O...
Hare is the step by step guide and the needed files to fix it: https://theandroid02.github.io/i9300-EMM...
The only thing you need after is a valid EFS partion backup to be restored to the phone, for example via the TWRP > terminal > dd command if you have a valid dd backup copy of your original EFS partion.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
uchika96 さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 36
今までの合計 12,589
