key stuck in ignition of old truck
The ignition key mechanism won't turn off or release key. I have been removing fuse to shut her down... It is stuck in "on." Turning of the steering wheel to relieve locking does not seem to help.
Any suggestions would be appreciated
Scott
Have 88 gmc truck key stuck in ignition in on position and won’t come out tried everything disconnected battery to start power
Tom mc さんによる
I've had the same thing happen, I've had luck twisting the key partially int the start position the back to off. the permanent solution is a new ignition cylinder
Casy Chapin さんによる
