メインコンテンツにスキップ
1.7GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.6 GHz)3MB L3キャッシュ
Is my SSD faulty or the cable connecting it?
I have the above model A1465 and I get the folder with the question mark upon loading.
I have tried the following:
1) Ran the Recovery feature both from Command+R, and used the internet recovery.
The download finishes and the apple logo comes up and then goes to the OSX utilities options. when I click on the Disk utility it finds "disk0" and underneath Mac OSX Base System, nothing more and all options are greyed out.
2) I have tried to reinstall MAC OSX
This brings up the OS version to install etc (OS X Lion) and gets to the point where it asks which disk to install to - but there are no options here.
So, what is the best methods to troubleshoot the problem (I do not have another mac to try) using a windows system or can you point me to the part numbers needed at least for the connecting cable.
Hope you can help and any is appreciated.
regards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Same problem here. Anyone?
さんによる
コメントを追加
1 件の回答
Sounds like the drive is bad or loose.
MacBook Air 11" Mid 2012 SSDの交換
This will show you how to remove it. Take it out and put it back in to see if that fixes the issue. If problem persists then you may need to get a new one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mr P さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 390
