My port is broke
How do u fix a broken port
Gavin, the charging port on th 7".8" and 10.1" tablets are all soldered to the circuit board. To replace those you will have to disassemble your tablet, remove the circuit board. then un-solder the old connector and replace with a new one. Sometimes it is the solder connection that has failed and a quick resolder might fix it. It will all depend on what tablet you have, your tools and your skills.
このアンサーは役に立ちましたか?
if taken to repair shop, is it exspensive?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 766
2 件のコメント
Gavin, what model is your nextbook? I suppose you are referring to the charging port?
oldturkey03 さんによる
yes, samsung model;sm-t230nu
Jr. Mike さんによる
