メインコンテンツにスキップ
The fourth generation Volkswagen Jetta, also called the MK4 or the Bora, is Volkswagen's family sedan.
85回答 すべてを表示
not shifting into overdrive
two things i would like to know the location of my tcm trans control modular in my 1999 vw jetta 2.0 newer body style. and why do you think the trans is not shifting into overdrive what should i look for mick
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
I have a 2002 Jetta 2.0 that wouldn't shift into overdrive. We changed a speed shift sensor, it didn't fix it. Come to find out, there's a speed shift sensor on top of the transmission under the transmission mount. It has a cord with a plug in attached to it, where as the other speed shift sensors don't have a cord connected to them. This fixes it. You also have to reset the transmission computer afterwards. So to do that turn the key in the on position without starting the car. Then hold down the gas petal for 30 seconds. That's it, good it go!!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Is it necessary to have a speed shift sensor for overdrive in the Jetta?
さんによる
コメントを追加
The TCM is below the wiper cowl along with the ECM. It might be low on ATF, which would prevent it from shifting into overdrive.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
As far as I know it has a sealed transmission.
さんによる
コメントを追加
Because attacks 5 and 1/2 Grand at because I have to drive it up to 40 miles an hour to get it to shift out of second and then I can put it up to 80 miles an hour and it won't shift again and I'm tacking 5 1/2 Grand
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i change the body valve whit at new wire conector and transs dont shift gears please helpme
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
RADIOFLYER さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 72
今までの合計 14,777
