メインコンテンツにスキップ
2015年1月発売。XPS 13ラップトップは”見た目はボーダレスなインフィニティディスプレイ”を搭載し、タッチスクリーンへアップグレード可能な、MacBook Airと対抗するべく開発されました。
Does anyone know how to tighten the hinge on this?
My xps 13 (2015) is making cracking noises along the hinge, and i think thats because the hinges are loose. Anyone know how to tighten it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
7 件のコメント
Hi, I am having this issue as well. Could you tell me how you removed the cover?
さんによる
I have the XPS 15, which is built very similarly. I'm also having this issue. You need a small set of torx screwdrivers to open up the back. I found a good set on amazon a while back for around $5 I think
さんによる
The trick is to find the screw under the service tag flap
さんによる
Anyone tried isasukexd's answer and still have this wobble?
さんによる
The dell XPS is famous for the loose hinge, then. My XPS L321X (2012) also have the issue.
Yes, the brackets under the backplate (screwed onto the chassis) can be loose, but it's not that loose. The screw that is the loosest is the one on the display.
How to tighten that?
First, open up the cover (like you are using it)
Use your fingers, pinch the top and bottom sides of the plastic part (on the screen). Then pull toward you. (away from the screen). A plastic tab on top should reveal.
Close the screen (like you are done using it). Use your hands, gently lift up the plastic part. Antennas should be connected to it. The screws are Philips white (can be black) ones behind the display cable and the antenna.
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Ive fixed it! If anyone else with an XPS 13 is having this issue, take the back off and tighten any loose screws on the top left and right, where the hinge is located.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
isasukexd さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 36
今までの合計 13,045
