メインコンテンツにスキップ
Sony Xperia Z3デュアルはSony Xperia Z3 D6633とも知られており、2014年9月に発売されました。146 x 72 x 7.3 mmの本体サイズでIP68認証済み、5.2インチディスプレイ、20.7Mpリアカメラを搭載しています。
27回答 すべてを表示
締切られた回答
Is there an integrated Screen-Case replacement part for Sony Z3
My repair tech told me (after the third screen fracture repair by him) that he replaced the parts with a combination part. Is there a product that has the front screen already inserted in the case? It Seems like he is scamming me to pay for an expensive repair that should have been covered by his 30 day warranty.
He fixed it after my mistake the first time... but the screen has been fracturing within a week after each repair. This will be the third fracture within a month.
NOTE: there is light leakage from the left side of the screen after each repair.
HELP
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Yes you can buy the screen and frame together. It is best to use if the frame on the damaged phone is bent because otherwise it would be difficult to get a screen to fit without lifting.
You should be able to tell once the repair is done if the frame around the screen looks new.
Here is an example. Sony Xperia Z3 Screen and frame.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 188
