メインコンテンツにスキップ
Kindle Touch (DD1200)はKindle 電子書籍リーダーの第四世代です。Wi-FiもしくはWi-Fi/3Gモデルがあり、USBケーブルでアップロード可能です。容量は4GBでバッテリーでバッテリー寿命は2ヶ月です。
24回答 すべてを表示
Home/Menu button does not work
The Home/Menu button of my Kindle Touch does not work. I can hear and feel the click, but it does nothing.
Is there a way to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
3件の回答
最も参考になった回答
Here’s what I did to reactivate my Home button. I surmised there was a buildup of crud in the switch mechanism that needed to be cleaned out. I chose 91% isopropyl alcohol because it was a high grade solvent that would mobilize the crud without leaving a residue or attacking the plastic. Don’t use plain rubbing alcohol because it has oils in the alcohol to facilitate “rubbing.”
1) Turn the unit off.
2) Take a napkin soaked in IPA and daub the raised portions, allowing a little to slip into the slots.
3) Before the IPA evaporates (and it will evaporate quickly!), work the button repeatedly.
4) Repeat as needed
Each cleaning cycle, things got better and after three, operation was great - took 5 minutes for the whole thing!
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
Yes! Totally worked as you described. Let's hope this solution lasts.
さんによる
Eric - Thanks for the tip. I actually pried off the front cover (not as easy as some video clips show) and cleaned the actual micro button with some iso p alcohol. Cleaned built up gunk (10 yr old Kindle) and now it WORKS. Thanks again.
さんによる
Thank you so much! I love my Kindle Touch 4Gen so much and will be so sad the day it truly stops working and I need to "upgrade" - I was so happy to find this simple solution that keeps it going for a little longer!
さんによる
Thanks! So simple and so effective!
さんによる
Yay!,,That worked! Thanks!! : ))
さんによる
1以上のコメントを表示
コメントを追加
Is the 'new home button' attached to the bezel, or to the motherboard in this case? And if it's just a shorted wire, what is involved with this repair?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You might have to just get a new home button or check and make sure that the connector is securely plugged into the logic board as it may have jarred loose, either that or a shorted home button wire.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Fernando Sancho さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 35
過去 30 日: 115
今までの合計 13,886
