メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
締切られた回答
Fickering black lines when on a phone call
Hi Guys,
Can you help with my query? I have an I Phone 4S, I cracked the screen several months ago, and used it for months like that with no problems.
I decided to get the screen replaced, so took it to a local shop to get it replaced. Since getting it fixed a new problem has appeared. When making or receiving a call,when the phone is away from my ear, I get these random black lines flickering over the screen. These lines are only present during a call, all other times, playing music, texting .watching videos etc everything is fine.
I took it back to the phone shop, they replaced the screen again, but the same problem is still there.
I have googled this fault, but there does not appear to be a solution.
Any ideas ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The ribbon cables are most likely pinched in some way. I would return the shop and demand that it be fixed. It is also possible that the FPC connectors were damaged while installing the new display.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 46
