メインコンテンツにスキップ
Lenovo Yoga Tab 2 not switching on
I bought a Lenovo Yoga Tab 2 1050 (Android) about 2 months back.
It worked quite well and I even updated it to latest version of Android( 5.0.1 I guess,its Lollipop but I don't quite remember the exact version).
About two days back I "Shut down" the tablet and since then its not turning on,shown on PC or even charging.
I even tried to go to recovery mode by pressing "volume button and power button" but nothing happens.
Bought the device in US but currently am in Nepal.
Can you please suggest a resolution for this issue.
The Issue is exactly similar to the one in this video
https://www.youtube.com/watch?v=Ayto-IwD...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Solved this issue by opening up the device and re-assembling it.
Issue seems to be due to faulty power cable (perhaps as battery is in the hinge of the device) .
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
How did you do this .. I disassembled the device and it has nothing to get off after you remove the back cover!
Model: Lenovo Yoga Tab 2 1050L (Android)
さんによる
I disassembled all the connectors and even removed the battery. Then, I removed the battery and then re-assembled it. The main issue,I think , was with the battery connector cable nudge it a little and see if that help.
Good Luck
さんによる
コメントを追加
回答を追加する
Biplab さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 4,371
