メインコンテンツにスキップ
7.9インチのディスプレイ、モデル番号A1432、黒と白色のモデル、発表日は2012年10月23日、サイズは16、32、64GBがあります。
220回答 すべてを表示
White lines on display and it wont work properly
Hello,
I replaced the front glass panel on the iPad mini. After I tried to turn it on I saw streaks on the display and the apple logo was blurred. I reopened all and checked all cable connections. All were connected properly.
Also if I try to slide the screen keeps black only the first lines at the top are moving.
Do you have any ideas what I can do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
If the display was fine before doing the repair check the connectors for any damage. Both on the digitizer and LCD.
Also look around the area where the connectors connect to the board and see if you can notice any damaged components. If everything looks fine you may have damaged the LCD during the repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This symptom is usually a sign of water damage. Could the device have gotten damp when the glass was damaged?
Did you replace the screen and digitizer with the glass? This is usually a good idea as damage to the glass usually results in damage to the screen below. Also it is hard to remove the old glass without damaging the ribbon.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
eric さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 169
