メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Apple diagnostics Ppt004 code
I ran apple diagnostic and got this battery service code. Telling me I should replace it.
When I check with battery health app it says the condition is good. And it has more then 200 cycles an 90% capacity.
Why the difference?
Should I replace the battery or leave it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
ベストアンサー
I have seen apple batteries only last for 300 cycles, i have seen batteries last for over 1000 cycles, its almost like a shotgun chance of how many cycles your going to get in my experience, I would visually check your battery to make sure that it is not swelling, sometimes they will do this when they are going bad but will not display any error messages or anything like that until it has swollen so much that it has crack a track pad and busted a few screws off the bottom plate, one sign that this is happening is that your track pad is not acting correct like highlighting stuff your not trying to, moving icons that your not trying to, selecting items while you are just scrolling your mouse across the screen, that kind of stuff
This is the exact explanation of that error code
PPT004 The battery requires service. The battery is not functioning normally, though you may not notice a change in its behavior or the amount of charge it holds. You can continue to use your battery before it’s checked without harming your computer.
Contact Apple or take your computer to an Apple Authorized Service Provider or Apple Retail Store to determine which service and support options are available.
ref: https://support.apple.com/en-us/HT203747
このアンサーは役に立ちましたか?
スコア 4
7 件のコメント:
Thank you very much for the respond!
opening the back panel to examine should suffice or you suggesting to fully take it out ?
Thanks again.
さんによる
yeah i think just taking the bottom plate off would do it, u will be able to clearly see if the battery is puffing up, it might just be one cell it might be the whole thing but u will be able to tell for sure without having to take it out
さんによる
Thank you very much!
さんによる
Your welcome
さんによる
I have encountered this error soon after replacing the battery for one from ifixit. The battery is brand new, is not swelling, and it is working great, but I am not happy with the error code. Is there something on the system that will recognized that the battery is not an OEM Apple part in which it throws this error? Should I return the battery to ifixit for a full refund? Also right after I replaced the battery the keyboard stopped working. It turns out that the battery replacement bricked the internal keyboard on my MacBook pro. I followed so many instructions from Apple and other sites in which now Apple wishes to charge me $200 to replace the entire metal panel with the battery and keyboard attached.
さんによる
2件以上のコメントを表示
コメントを追加
最も参考になった回答
Attempted 3 3rd party batteries in my Mid 2013 MBA all with the same error code PPT004. Swapped the last one with an official Apple Battery and no error code. I think this maybe a case of Apple Shenanigans.
このアンサーは役に立ちましたか?
スコア 8
コメントを追加
I have this error too after replacing the battery in my 2015 MacBook Pro 15” Retina. The battery is behaving normally and Coconut Battery App gives it a clean bill of health.
I suspect too, protectionism by Apple who always seem resistant to any third party being involved in their machines as evidenced by the fact the latest machines cannot change RAM or SSD.
I love this machine, but if I need to replace it, it will be with a Linux one. Apple have lost the plot to me, they’re far too arrogant for me.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
I had the same problem. I just let the battery die and then charged it up until 100%. the problem is gone.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Please give us the last four figures of your serial number. Also go here and enter you serial number and check your warranty expiration date. https://selfsolve.apple.com/agreementWar...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hello,
This - G3QR ?
Unfortunately warranty expired.
さんによる
コメントを追加
回答を追加する
stellern さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 47
今までの合計 16,012
