メインコンテンツにスキップ
A Sony camera in the HX series of the Cyber-shot line.
5回答 すべてを表示
締切られた回答
Why am I being requested to turn off and then back on?
When I turn the camera on the lens pops in and out and I am instructed to power down the camera and then power it back up again, but results do not change. The battery is charged, the memory card is in place, the camera is clean. The camera simply stopped working and this error message keeps appearing, how do I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Donald Rankin, this behavior is common with a lens error. If your camera senses that it can not extend or retract the lens it requests a reset. Since it does not resolve it, you probably will have to replace the lens. Check on here for a few suggestions you could try. Ultimately it sounds like a new lens is needed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 312
