What can I do if I forget my password?
Someone stole my ipod and changed the password when i found it i didn't know the password so i need help.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can do it, but it requires the iPod touch to be reset, hopefully you have synced it recently with iTunes before it was stolen?
Ok so connect your iPod to iTunes
Hold power button and Home button (circle button) at the same time, maybe around 8 to 10 seconds.
It should now reboot (screen will go off), release JUST the power button, keep home button held down.
iTunes will say it has found an iPod in recovery mode.
Now just restore your iPod with your iTunes.
It will wipe everything first, then put it back on.
このアンサーは役に立ちましたか?
Dude. thank ou so much.
OMG it will delete all my photos!!!
Can’t access your iPod? To reset a lost iPod password, follow these instructions.
1. Plug your iPod into your computer.
2. Make sure you have the latest version of iTunes.
3. If necessary, back up all your music. Though you may think that this is impossible with a locked iPod, the screen lock only protects the iPod interface itself; it doesn’t protect/encrypt any of the data inside, meaning you can still access it from your computer.
4. Restore your iPod. This will clear its contents and restore all factory settings.
5. Re-sync your iPod and apply a new password.
More from: http://www.wikihow.com/Reset-a-Lost-iPod...
このアンサーは役に立ちましたか?
Well, i just have the same experience with you. forgetting the passcode of a iDevice, but my iDevice is an iPad. But i think maybe the way to solve the problem is similiar, so i recommend you to refer to https://www.isunshare.com/iphone-ipad/re....
Hope to be helpful.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 5,574
