メインコンテンツにスキップ
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
90回答 すべてを表示
Why is my Xbox 360 PC wireless controller stuck on player 2?
my Xbox 360 PC wireless controller is stuck on player 2, sometimes player 3. It used to be on player 1 , but now I cant use it, I checked drivers, removed some usb drivers, checked device and printers... but still it displays the player 2 light. :(
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
I solved the same issue, at least for me. If you have any game streaming service (Such as Kinoi Streamer or the like) Remove it!!! That auto assigns itself to player 1, thus defaulting your controller to player 2! I Uninstalled it, and my controller defaulted to player 1 again!
このアンサーは役に立ちましたか?
スコア 23
13 件のコメント:
Yup, that's what it was for me. You rock man.
さんによる
That was exactly it! Thanks dude!
さんによる
i tried doing the drivers thing for about a week straight and was baffled, i wish i had found this answer sooner. it worked pretty much /instantly/
さんによる
yes that what is was for me thanks you nicky ! :d
さんによる
Wow! Thanks man!
さんによる
8件以上のコメントを表示
コメントを追加
Carlos Daniel, I'd start by trying to resync the controller. Check on here Should it still do this after, try a different controller. This will determine if the controller is sending wrong signals or the receiver board is failing. some of it will depend on which version Windows you are using.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I guess another wire controller is connected to your PC. It is defined as player 1. That's why your controller stuck on player 2.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Did not work.
Windows 10, all game controllers default to player 2.
Tried restarting,
uplugging and restarting,
deleting drivers and restarting,
removing al streaming software, deleting drivers, and restarting,
still the controller will not work.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Ok, it does work, it just doesn't look like it would.
The player two LED lights up, but when I turn on a game it allows me to play it with the controller.
I guess as long as I don't look at my mouse while the game is on, I should be fine.
Thanks guys.
さんによる
try using this https://goo.gl/akhQg2
さんによる
コメントを追加
回答を追加する
Carlos Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 44
今までの合計 48,884
