Logic Board Solder Pads Touch Screen FPC
Have a customers iPhone 5s in which has damage to the FPC Touch screen connector pads. There are quite a few pads missing and was wondering if this could be fixed or not.
Thanks
この質問は役に立ちましたか?
Thanks
この質問は役に立ちましたか?
I could probably be fixed by a well skilled microsolderer but it won't be cheap.
このアンサーは役に立ちましたか?
From what I can tell, it should be repairable, as long as the traces in the board are still OK. In these situations, I generally use some copper wire from a backlight coil and make a jumper from the exposed trace to the connector.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 202
